17 years agoCyclone III StarterKit EP3C25F324C6 DDR-Problem
Hi everyone, i have a problem with a small example configuration of a Nios II System using DDR. I use quartus 8.1 full license. I get fitting errors which tell me the following: -----------------...
17 years agoThere is a TCL script included with the Cyclone III kit that when ran changes the constraints and allows the design to compile.
Tools> TCL Scripts > ddr_pin_assignments.tcl > Run That will allow it to compile. Read the comments if you have changed any of the default names. This was found in the DDR high performance controller PDF.
