17 years agoCyclone III StarterKit EP3C25F324C6 DDR-Problem
Hi everyone, i have a problem with a small example configuration of a Nios II System using DDR. I use quartus 8.1 full license. I get fitting errors which tell me the following: -----------------...
17 years agoDear Mike,
i used a megafunction of quartus 8.2 for connecting the DDR-Ram and i used the documented pinout of the dev-kit. Since there is no pin assignment documented in the pqf files according T6, i'm a little bit confused about the error. So i don't know where the wrong pin assignement is done. I didn't do it.... Where and how can i search for the wrong pin which is not shown in the pin assignment editor? Best regards, Frank
