14 years agoCyclone III starter board problem at power on
I use a Cyclone III starter board, I uploaded on the flash a .pof file, everything was ok. Today something strange happens: the board stops to run. I turn it off then I turn it on: the FLASH_CEN l...
14 years agoNo, it isn't the DE0 board, it's the Cyclone III Starter Kit (http://www.altera.com/products/devkits/altera/kit-cyc3-starter.html).
However, the problem is that everything worked, then, since yesterday, if I reboot the board it doesn't load any configuration. In your opinion the hardware is in some way damaged or there may be any other problems?
