Cyclone III Development board errata
Hello everyone,
I've designed a new system from scratch on the cyclone iii development board (http://www.altera.com/products/devkits/altera/kit-cyc3.html) and I found a few errors in the files provided by Altera. I don't think I've seen them before on the forum, so I thought I would share them with you, so that you don't loose as much time as me to find them out ;) SRAM pins 4 pin assignments on the flash/sram data bus are wrong, on the "cycloneIII_3c120_dev_my_first_fpga", "cycloneIII_3c120_dev_niosII_standard" and "cycloneIII_3c120_dev_quartus_pinouts" design examples. 2 of these pins are connected to ground, which makes it somewhat difficult to write what you want in the SRAM. Only the upper word is concerned, so the flash (that only uses the lower word) is not affected. You must change the following assignments:fsd PIN_C8 -> PIN_B8
fsd PIN_D9 -> PIN_C8
fsd PIN_F11 -> PIN_D9
fsd PIN_F10 -> PIN_E7 The second error is in the reference manual, page 2-39. It says that the chip select pins for both the character and the graphical LCDs are connected to pin AB24. The chip enable for the text LCD is in fact connected to pin AC24. The example designs are correct though. On a personal note I found the name they gave the LCD pins very confusing, because it is impossible to tell which signals are common to the two LCD displays, and which are specific to one of them. I renamed the signals to something like lcd_txt_*, lcd_gr_* and kept only the names lcd_* for common signals. Is there a way to tell this to Altera so that they can correct all this for the next version?16 Replies
How did you determine the correct pins? - Altera_Forum
I looked at the schematic. It's the only reliable source of information on Altera's kits.
one more,
CLKIN_50 is connected to pin AH_15 - Altera_Forum
--- Quote Start --- one more, CLKIN_50 is connected to pin AH_15 --- Quote End --- And what is incorrect? - Altera_Forum
Reference manual says, CLKIN_50 is propagated from pin E13. But, these are the actual connections
pin E13 -> CLKIN_50_EN pin AH15 -> CLKIN_50 - Altera_Forum
Could this pin assignment mistake make display creazy?
In particular a very strange set of characters are visible on my LCD... - Altera_Forum
Check that you are using the correct FPGA pin for chip select (AC24).
Are you providing a reset pulse to the LCD before writing to it? - Altera_Forum
Ciao Daixiwen
yesterday night I solved this issue and I was too tired for reply to my comment. the mistake is linked to misalignment between lcd_out_from_nios and LCD_DATA pinout. They are connected 0 with 7 1 with 6 and so on... For the other pin assignment now all it's ok even if I can't find the right associtaion with LCD CONT and I can't change the contrast of my LCD. By take a look to schematic I can't find the pin on DE0 board (NO NANO) that i have to modify in order to change contrast. the only info is LCD_CONT but which is the right pin to use???? Anyway really thanks for your support and your help. regards - Altera_Forum
I don't think there is any pin connection to the FPGA to control the contrast. Some LCD modules have a screw you can adjust for the contrast, some others use a special command on the parallel bus, and some use a pin. The the latter group is there is no connection to the FPGA (and it seems to be that way, according to the DE0 manual) then you may need to add a little circuit of your own to control it.
By the way this thread is about the Altera Cyclone III development board, which is different than the DE0. - Altera_Forum
The DE0 schematic is pretty clear about the LCD_CONT connection, I think. It's derived from a fixed voltage divider.
