9 years agoCyclone III Development Board - Video Image Processing Suite - Hardware revisions?
Hi, I'm using the Cyclone III Development Board and the Video Image Processing Suite for many years. I use the VIP-reference-design on some boards from the year 2007 a it's working fine. ...
8 years agosolution for the DDR2-RAM (no solution for the utram yet):
The are two possible solutions for this issue. The first solution means compatibility with the old Hardware, the second solution will use the new full memory of DDR2-RAM (bottom and top) preparatory work for both solutions: Go to pin planner and add the node: "memtop_ba[2]" to PIN_C23, IO-Standard SSTL-18 Class I, 12mA Go to pin planner and add the node: "membot_ba[2]" to PIN_AH4, IO-Standard SSTL-18 Class I, 12mA First solution (compatibility with old boards) -simply tie the new both Pins to ground Second solution (use the new more memory) -go to QSYS / SOPC-Builder => DDR2 SDRAM Controller with Altmemphy => Memory Settings => modify parameters => bank address width => Change from 2 to 3 repeat it for both (top and bottom) DDR2 Best Regards Mark
