17 years agoCyclone III / Bitec Video Dev Kit
Hi
I got the Cyclone III dev kit a few days ago together with the Bitec dvi in/out and the quad comp board. First I tried to run the 71 vesion of Quartus II and Nios II on Vista ...no luck I then downloaded the ver 81 of both and still had problems on Vista then I installed on Xp and it seems to work :-) I can do the Counter demo in QuartusII, great I can do the Hello World in Nios II, great Then I try to do the Moasic for 4xcomp with the Bitec code and I can build all. But when I do right click on "hsmc_quad_video_demo and select run as Niro II hardware it do build a bit more and try to download with this result Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloading 00000000 ( 0%) Downloaded 9KB in 0.1s Verifying 00000000 ( 0%) Verify failed between address 0x0 and 0x200F Leaving target processor paused I would be very happy if someone have a good hint to get pass this point Thank you Wiljan11 Replies
i think you will have to buffer more than a line at a time to rotate the video.
