10 years agoCyclone 5 GX Starter Kit SMA Impedance
Hey all, I recently purchased the Cyclone 5 GX Starter Kit. I want to use the SMA transceiver ports to both output and receive that through an optical link. I also plan on using the transceiver...
10 years agoBy the way, why do you need the impedance value? If you are using XCVR toolkit, it will help to find the optimal analog settings according to your setup.
