Cyclone 10GX with 2 port SFP 1G test.
- 5 years ago
Hi SengKok! All issues have been resolved. This error is caused by CLK signal for GXB. My custom broad Cyclone10GX ran successful 2 port SFP 1000 Base-X and 2 port 1000 Base-T. Thank!
Is the problem only happen in your custom board, where there C10 GX development board is working fine?
Do both channels pass the TEST_SMA_LB test?
- TRAN_HIEU_0075 years ago
I have tested successfully with TEST_PHYSERIAL_LOOPBACK and TEST_SMA_LB in both broad (My custom broad and C10 GX development board). Moreover, I do not understand why when I disconnect SFP cable TEST_SMA_LB still successful. This is my project test in Quartus 18.0 https://drive.google.com/file/d/1F2bbFeMCh-TXbeFQpxwCKBGHeSaQj4gC/view?usp=sharing
Can you give true project test SFP 1G for Cyclone10GX. I need ping from my computer to custom broad over SFP module and TSE IP.
