Cyclone 10GX JTAG Programming
Dear Anand,
When the board is powered ON with MSEL pins in AS mode: nCONFIG is continuously high & CONFIG_DONE is continuous low. nStatus is going high & low like clock signal. The board is in continuous loop as shown in the attached image (Figure141 of Handbook). Writing the configuration data to FPGA is not happening.
nStatus will become high if I load .sof file through JTAG, as expected. Also CONFIG_DONE goes high after programming.
Bhagavath
- AnandRaj_S_Intel7 years ago
Hi Bhagavath,
We can finally suspect the flash device.
Let me escalated this case to AE. I will get back to you on this soon.
Anand
- KBhag37 years ago
Dear Anand,
I have captured the top marking of the Micron Flash & the same is attached. Not sure if this will help.
Do you suggest any footprint compatible alternate part? I will quickly procure few of them & try if that helps.
Bhagavath
- KBhag37 years ago
Dear Anand,
I have check with Micron about the top marking & the device top marking is correct.
https://www.micron.com/support/tools-and-utilities/fbga?fbga=RW170#pnlFBGA
Bhagavath
- KBhag37 years ago
Dear Anand,
Please let me know if you have any further update regarding this issue.
Bhagavath
