KBhag3
7 years agoCyclone 10GX JTAG Programming
Hi, I am using Cyclone 10GX in one of my design. When I started testing my board, JTAG was not functioning properly. I could program Cyclone10 through JTAG at 1MHz but not beyond that. I tried diffe...
KBhag3
7 years agoDear Anand,
Thanks for your response.
Yes, my VCCPGM is 1.8V. I have attached the FPGA Power section Schematics.
Auto detect also is working at 1MHz only.
I need some time to capture the images.
Bhagavath
AnandRaj_S_Intel
7 years agoHi Bhagavath,
Good to know that you have solved the problem.
- Yes MT25QU is supported device.
- Have you set the MSEL pins of the FPGA devices to the AS configuration mode?
- The Generic Serial Flash Interface Intel FPGA IP core provides access to Serial Peripheral Interface (SPI) flash devices.
If still facing problem try to work with the example given in the link so that narrow down the issue.
Please do refer below link
https://www.intel.com/content/www/us/en/programmable/documentation/tkt1520669802999.html#rku1522581481513
Best Regards
Anand
