Cyclone 10GX JTAG Programming
Hi Bhagavath,
Is your VCCPGM =1.8v?
Is auto detect working at higher frequency ?
Can you capture TCK,TMS,TDI , nSTATUS CONF_DONE & nCONFIG and attach ?
Anand
- KBhag37 years ago
Dear Anand,
Thanks for your response.
Yes, my VCCPGM is 1.8V. I have attached the FPGA Power section Schematics.
Auto detect also is working at 1MHz only.
I need some time to capture the images.
Bhagavath
- AnandRaj_S_Intel7 years ago
Hi Bhagavath,
Good to know that you have solved the problem.
- Yes MT25QU is supported device.
- Have you set the MSEL pins of the FPGA devices to the AS configuration mode?
- The Generic Serial Flash Interface Intel FPGA IP core provides access to Serial Peripheral Interface (SPI) flash devices.
If still facing problem try to work with the example given in the link so that narrow down the issue.
Please do refer below link
https://www.intel.com/content/www/us/en/programmable/documentation/tkt1520669802999.html#rku1522581481513
Best Regards
Anand
- KBhag37 years ago
Dear Anand,
I have changed my USB-Blaster II cable & now FPGA is getting programmed successfully at 24 MHz. Also, it is getting programmed consistently.
I have programmed my .jic file to Micron Flash & the file is getting programmed. However, FPGA is not able to read the Flash in Active Serial Mode.
The Flash part no. I used is MT25QU256ABA8ESF-0SIT. Please let me know if this part is supported by the device. I am using Quartus 18.1 PRO.
Also I would like to know if any other customer has used this Micron part along with Cyclone10 GX device for configuration.
Thanks for your support.
Bhagavath
- KBhag37 years ago
Dear Anand,
MSEL is set properly for AS mode & I could see DCLK. I have noticed that DCLK, CS & D0/D1 are continuously toggling. I have attached some of the captured waveforms. Let me know if you get any clue from this.
Bhagavath
