RBach6
7 years agoCyclone 10GX eval board serdes pin mapping question
Hi, I designed a board with high speed adc,dac and clock on an fmc board to match with the fmc connector on the cyclone 10gx eval board. For the most part it is working good. I am running into an is...
SreekumarR_G_Intel
7 years agoHello ,
Can you try to promote the reference clock (clock input) manually ?
Here is the quartus prime setting assignment ,
set_instance_assignment -name GLOBAL_SIGNAL GLOBAL_CLOCK -to <name of toplevel reference clock input port>
kindly let me know how it go ?
Thank you ,
Sree
Like
