Cyclone 10 LP Evaluation Kit Pinout issue
- 1 year ago
D6, D7, D8, and D9 are the board references on the silkscreen, not device pin numbers, so L14, K15, J14, J13 are correct.
As for why it looks like a power pin is showing up at location L14, check to see if that is perhaps a dual function pin.
Can you point out the discrepancies you've found and links to the documents you are referring to?
- Kenvwhite1 year ago
From Mouser https://www.mouser.pl/datasheet/2/612/ug_c10_lp_eval_kit-1144689.pdf
From Board Design Files: https://www.intel.com/content/www/us/en/developer/articles/tool/intel-cyclone-10-lp-fpga-evaluation-kit-downloads.html I dowloaded Kit zip from here.
But also in Design files pins for those User LED's have diff pinout I know that in PDF pins have the same description as on the top of the board and description in this schematics refers to Cyclon pinout.
The case is none of them could be used in Quartus, because those pins have another assignment as I know.
I have tried every of those pins and none of them works to blink User LED.
F.e. pins D6, D7, D8, D9 in PDF are L14, K15, J14, J13 in schematics.
