Cyclone 10 LP Evaluation Kit Pinout issue
I recently purchased EK-10CL025U256 with Cyclone 10CL025YU256I7G and the problem is probably the documentation.
Also regarding to this: https://www.intel.com/content/www/us/en/docs/programmable/683580/current/evaluation-board-revisions.html
I have revision A2.
D6, D7, D8, and D9 are the board references on the silkscreen, not device pin numbers, so L14, K15, J14, J13 are correct.
As for why it looks like a power pin is showing up at location L14, check to see if that is perhaps a dual function pin.
- sstrell
Can you point out the discrepancies you've found and links to the documents you are referring to?
- Kenvwhite
From Mouser https://www.mouser.pl/datasheet/2/612/ug_c10_lp_eval_kit-1144689.pdf
From Board Design Files: https://www.intel.com/content/www/us/en/developer/articles/tool/intel-cyclone-10-lp-fpga-evaluation-kit-downloads.html I dowloaded Kit zip from here.
But also in Design files pins for those User LED's have diff pinout I know that in PDF pins have the same description as on the top of the board and description in this schematics refers to Cyclon pinout.
The case is none of them could be used in Quartus, because those pins have another assignment as I know.
I have tried every of those pins and none of them works to blink User LED.
F.e. pins D6, D7, D8, D9 in PDF are L14, K15, J14, J13 in schematics.
- sstrell
- sstrell
LEDs are active low.
- Kenvwhite
Oh god, finally works. Thank you a lot!
- AqidAyman_Altera
- AqidAyman_Altera
- Kenvwhite
Maybe my program is a problem or a upload to the board even if it's successful. I've tried statically turn on the LED, but nothings change.
After a few minutes D6, D7, D8, and D9 automatically starts blinking. This state is from the beginning and nothings changing it.library IEEE; use IEEE.STD_LOGIC_1164.ALL; entity ONE_LED_BLINK is Port ( led : out STD_LOGIC ); end ONE_LED_BLINK; architecture Behavioral of ONE_LED_BLINK is begin led <= '1'; end Behavioral;
