JLuke3
7 years agoCyclone 10 LP Evaluation Kit Configured LED not lit.
Have had this device for some 2 weeks After trying to download golden ref system from Board test system on next power up only blue power LED on. Reset and configure buttons have no effect. Jtagco...
AnandRaj_S_Intel
7 years agoHi John,
If you using jtag header check the sw1.4.
Use embedded blaster on board and check if you can program.
Try to load below file attached .jic file (for epcq128) using usb port.
Anand
JLuke3
7 years agoOK Thanks that has fixed it. Now configure led on and 3 bit counter on other leds
I must have overwritten the flash somehow. Was afraid I might have blown the board up.
I followed the procedure on page 16 of ug_c10lp_eval_kit.pdf.
4.4.2 Program on-board EPCQ flash with the TEST.jic file which actually
seems to be epcq64.
John Luke
- AnandRaj_S_Intel7 years ago
Hi John,
Good to know that you have solved the issue.
Yes ,TEST.jic file which actually for epcq64.
Anand
