Afari6
7 years agoCYCLONE 10 GX I/Os spec
Hi, I already use xilinx FPGA but it's my first time about INTEL FPGA and i need help. I need to develop a camera with lvds I/Os @ 960MHz . I thinks that i will use Cyclone 10 Gx but i have somes pr...
Afari6
7 years agoHi SooYL,
Thanks for the response. It's clear now that cyclone 10 GX cannot bE used with the sensor without performance degradation.
Can you confirm me that it's the same things with ARRIA 10?
In datasheet, i can see that for LVDS the limitation is the same (700Mbps) but i see nothings about RSDS limitations.
If problems is the same with ARRIA 10, do you have a component that can manipulate LVDS INPUT @ 960Mbps with VDCM = 0.9 and VOD between 0.1(min) and 0.2V(max). ?
