OlegT
5 years agoCyclone 10 GX FPGA Development Kit - PCIe AvalonMM-DMA example
Hello.
I use AN829 as starting point of my design.
In Platform Builder I see, that PCIe hip is connected to DDR3 emif via avalon MM bus.
Both components use different clock sources, but they ar...
- 5 years ago
Hi Oleg,
Thanks for your patience while I was checking the design.
If you refer to the Platform Designer: Interconnect Requirements, there are some settings that allow the software to automatically insert the clock crossing adapters and add pipeline stages to the Platform Designer interconnect when you generate a system.
In our case, the clock crossing adapter type is set to FIFO and maximum pipeline stages is set to 4.
KhaiY
KhaiChein_Y_Intel
5 years agoHi Oleg,
Please allow me some time to check on this.
KhaiY
