User1589866279049382
6 years agoCyclone 10 GX Development Kit ddr problem
When i use bts to test the board. In ddr test. It always show DDR Calibration Error. Does any one ever meet this problem?
Deshi_Intel
6 years agoHi,
Byright dev kit BTS shouldn't be showing DDR3 calibration error unless you have a defective dev kit board.
- May I know is this totally new board or existing board that have been used for sometime ?
- BTS is quite sensitive to Quartus version in used. Do you used the exact Quartus version which is Quartus Pro edition v17.1
- Another debug suggestion is to create DDR3 example design from EMIF IP following the DDR3 setting used in BTS design. This should help to isolate whether the issue resides in BTS or the dev kit board itself.
dlim
