Oliver_I_Sedlacek
Contributor
2 years agoCyclone 10 GX dev kit, which signal can I use to reset a NIOS?
I've had a look at the Cyclone 10 GX dev kit user manual and schematics but it's not clear if the board provides a signal to the C10 that will drive the NIOS platform reset input correctly. Any sugge...
wwanalim_intel
Contributor
2 years agoI am sorry for the picture above. Below I reattached the picture.
You can enable Include cpu_resetrequest, and use a PIO IP as input into cpu_resetrequest.
Or, with the connection below made, use the debug module to reset the core only.
If the same signal is connected to other IP's reset, you can extend to full system reset.
Oliver_I_Sedlacek
Contributor
2 years agoThis seems to be a way to add more reset (sink) inputs. I'm looking for a reset source to drive the reset input after FPGA configuration.
