Cyclone 10 GX dev kit, which signal can I use to reset a NIOS?
Thank you for reaching us.
You can enable Include cpu_resetrequest, and use a PIO IP as input into cpu_resetrequest.
Or, with the connection below made, use the debug module to reset the core only.
If the same signal is connected to other IP's reset, you can extend to full system reset.
You also can refer below link about this.
I am sorry for the picture above. Below I reattached the picture.
- Oliver_I_Sedlacek2 years ago
Contributor
This seems to be a way to add more reset (sink) inputs. I'm looking for a reset source to drive the reset input after FPGA configuration.
