Cyclone 10 Evaluation Kit License
- 6 years ago
Hi Ahmed,
You can simulate license IP core without license if you are using Intel IP Evaluation Mode and you would need license only if you want to have production. The issue could be due to your support simulator which has license or not. For Intel Modelsim AE, you will need license and Start Edition is otherwise. Also refer to each IP core's user guide for parameterize steps and implementation
details.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_ethernet.pdf
You may have to refer to link below related to AN 320: Using Intel® FPGA IP Evaluation Mode
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an320.pdf
Hi Ahmed,
You must obtain a license for the Intel FPGA IP to generate programming files that you may use for an unlimited time. To obtain a license file, visit the Self-Service Licensing Center or contact your local Intel FPGA representative. May refer to link below.
Contact your local sales or distributor for more details.
https://www.intel.com/content/www/us/en/partner/where-to-buy/overview.html
- AMare26 years ago
Thank you for your reply. I managed to generate a time-limited sof file for testing. Is a license for the IP Core also required for simulation? I am getting an error concerning the TSE Core when I try starting the simulation. I thought it was possible to simulate the design for testing before buying the IP Core license.
Thank you.
