gweitzman
5 years agocvo not outputting separate syncs
Hi I am new to this site. I have a cyclone V and am trying to drive both a LCD and VGA using the CVO out. I have set the CVO to separate syncs. The LCD (640x480) kind of works, DE signal to LCD sy...
CheepinC_altera
5 years agoHi,
As I understand it, you have some inquiries related to the CV CVO with separate sync. To facilitate further debugging, just would like to check with you on the following:
- Just wonder if you have had a chance to try with Modelsim simulation to see if can replicate similar observation? This could help to isolate any functional issue prior to hardware testing.
- To ease the debugging, I would recommend you to start with simple design ie TPG -> CVO in simulation.
- What is the Quartus version that you are using?
gweitzman
5 years agoHi,
where can I find an example of TPG->CVO to simulate?
