cvo not outputting separate syncs
Hi I am new to this site. I have a cyclone V and am trying to drive both a LCD and VGA using the CVO out. I have set the CVO to separate syncs. The LCD (640x480) kind of works, DE signal to LCD sync structure is incorrect and the separate H and Vsync outputs are inactive.
Is there anything in the CV GUI that could keep separate sync option off?
- CheepinC_altera
As I understand it, you have some inquiries related to the CV CVO with separate sync. To facilitate further debugging, just would like to check with you on the following:
- Just wonder if you have had a chance to try with Modelsim simulation to see if can replicate similar observation? This could help to isolate any functional issue prior to hardware testing.
- To ease the debugging, I would recommend you to start with simple design ie TPG -> CVO in simulation.
- What is the Quartus version that you are using?
- gweitzman
where can I find an example of TPG->CVO to simulate?
- CheepinC_altera
Regarding your inquiry on the simulation example, for your information, you can create a simple Qsys system with TPG -> CVO with your targeted configuration. Then go to Generate -> Generate Testbench System. You can then further customize the test bench ie connecting the clocks according and the run through Modelsim simulation.
- gweitzman
I am almost there. Generated the TB and successfully compiled but couldn't simulate.
here are some of the errors:
vsim work.TPG_CVO
# Start time: 14:02:16 on Oct 16,2020
# Loading work.TPG_CVO
# Loading work.TPG_CVO_alt_vip_cl_tpg_0
# ** Error: (vsim-3033) C:/NDT/520/FPGA/TPG_CVO/TPG_CVO/synthesis/submodules/TPG_CVO_alt_vip_cl_tpg_0.v(72): Instantiation of 'alt_vip_video_output_bridge' failed. The design unit was not found.
# Time: 0 ps Iteration: 0 Instance: /TPG_CVO/alt_vip_cl_tpg_0 File: C:/NDT/520/FPGA/TPG_CVO/TPG_CVO/synthesis/submodules/TPG_CVO_alt_vip_cl_tpg_0.v
# Searched libraries:
# C:/NDT/520/FPGA/TPG_CVO/simulation/modelsim/rtl_work
# Loading sv_std.std
# Loading work.TPG_CVO_alt_vip_cl_tpg_0_scheduler
# ** Error: (vsim-3033) C:/NDT/520/FPGA/TPG_CVO/TPG_CVO/synthesis/submodules/TPG_CVO_alt_vip_cl_tpg_0_scheduler.sv(75): Instantiation of 'alt_vip_tpg_multi_scheduler' failed. The design unit was not found.
# Time: 0 ps Iteration: 0 Instance: /TPG_CVO/alt_vip_cl_tpg_0/scheduler File: C:/NDT/520/FPGA/TPG_CVO/TPG_CVO/synthesis/submodules/TPG_CVO_alt_vip_cl_tpg_0_scheduler.sv
# ** Error: (vsim-3033) C:/NDT/520/FPGA/TPG_CVO/TPG_CVO/synthesis/submodules/TPG_CVO_alt_vip_cl_tpg_0.v(124): Instantiation of 'alt_vip_tpg_bars_alg_core' failed. The design unit was not found.
# Loading work.alt_vipitc131_IS2Vid
# Loading work.alt_vipitc131_common_sync
# Loading work.alt_vipitc131_common_trigger_sync
# Loading work.alt_vipitc131_IS2Vid_control
# Loading work.alt_vipitc131_IS2Vid_mode_banks
# Loading work.alt_vipitc131_IS2Vid_calculate_mode
# Loading work.alt_vipitc131_common_generic_count
# Loading work.alt_vipitc131_common_fifo
# Loading work.alt_vipitc131_IS2Vid_statemachine
# Error loading design
# End time: 14:02:16 on Oct 16,2020, Elapsed time: 0:00:00
# Errors: 3, Warnings: 0
vsim work.TPG_CVO_tb
# vsim work.TPG_CVO_tb
# Start time: 14:03:09 on Oct 16,2020
# Loading work.TPG_CVO_tb
# Time: 0 ps Iteration: 0 Instance: /TPG_CVO_tb/tpg_cvo_inst/alt_vip_cl_tpg_0 File: C:/NDT/520/FPGA/TPG_CVO/TPG_CVO/synthesis/submodules/TPG_CVO_alt_vip_cl_tpg_0.v
# Time: 0 ps Iteration: 0 Instance: /TPG_CVO_tb/tpg_cvo_inst/alt_vip_cl_tpg_0/scheduler File: C:/NDT/520/FPGA/TPG_CVO/TPG_CVO/synthesis/submodules/TPG_CVO_alt_vip_cl_tpg_0_scheduler.sv
# ** Error: (vsim-3033) C:/NDT/520/FPGA/TPG_CVO/simulation/modelsim/rtl_work/TPG_CVO_tb.v(81): Instantiation of 'altera_avalon_st_sink_bfm' failed. The design unit was not found.
# Time: 0 ps Iteration: 0 Instance: /TPG_CVO_tb File: C:/NDT/520/FPGA/TPG_CVO/simulation/modelsim/rtl_work/TPG_CVO_tb.v
# ** Error: (vsim-3033) C:/NDT/520/FPGA/TPG_CVO/simulation/modelsim/rtl_work/TPG_CVO_tb.v(97): Instantiation of 'altera_avalon_clock_source' failed. The design unit was not found.
# ** Error: (vsim-3033) C:/NDT/520/FPGA/TPG_CVO/simulation/modelsim/rtl_work/TPG_CVO_tb.v(104): Instantiation of 'altera_avalon_reset_source' failed. The design unit was not found.
# ** Error: (vsim-3033) C:/NDT/520/FPGA/TPG_CVO/simulation/modelsim/rtl_work/TPG_CVO_tb.v(109): Instantiation of 'altera_conduit_bfm' failed. The design unit was not found.
# ** Error: (vsim-3033) C:/NDT/520/FPGA/TPG_CVO/simulation/modelsim/rtl_work/TPG_CVO_tb.v(136): Instantiation of 'altera_avalon_st_source_bfm' failed. The design unit was not found.
# ** Error: (vsim-3033) C:/NDT/520/FPGA/TPG_CVO/simulation/modelsim/rtl_work/TPG_CVO_tb.v(152): Instantiation of 'altera_avalon_clock_source' failed. The design unit was not found.
# ** Error: (vsim-3033) C:/NDT/520/FPGA/TPG_CVO/simulation/modelsim/rtl_work/TPG_CVO_tb.v(159): Instantiation of 'altera_avalon_reset_source' failed. The design unit was not found.
# ** Error: (vsim-3033) C:/NDT/520/FPGA/TPG_CVO/simulation/modelsim/rtl_work/TPG_CVO_tb.v(167): Instantiation of 'altera_avalon_clock_source' failed. The design unit was not found.
# ** Error: (vsim-3033) C:/NDT/520/FPGA/TPG_CVO/simulation/modelsim/rtl_work/TPG_CVO_tb.v(174): Instantiation of 'altera_avalon_reset_source' failed. The design unit was not found.
# End time: 14:03:09 on Oct 16,2020, Elapsed time: 0:00:00
# Errors: 12, Warnings: 0- gweitzman
Still having problems. Tried to simulate and here is the latest error list.
