ZhiqiangLiang
1 year agocustomize automatically generated base address in Platform Designer
Hi, in Platform Designer, I added several IP, such as JTAG, NIOS, RAM, ROM and etc. The automatically generated base address are: 0x0008_0800, 0x0008_1368, 0x0002_0000 and etc. I would like to m...
ZhiqiangLiang
1 year agoHi,
The automatically generated base address are: 0x0008_xxxx, 0x0006_xxxx, and 0x0002_xxx.
I would like to fix one base address to a certain address, for example: fix 0x0008_1100 to 0x0007_0000.
The questions are:
1) what is the available base address? 0x0007_XXXX works or not? is there any other base address that is available?
2) where is the doc that tells me what base address is available?
- sstrell1 year ago
1) The base address has to be set so that the address span of the agent interface doesn’t overlap with the address span for any other agent interface connected to the same host. You can choose any address you want as long as there is no overlap. The tool informs you immediately if there is overlap.
2) There’s no document. Every design is different. Just choose a base address and make sure you get no errors about overlapping addresses.
