NZami
7 years agocustom serial flash interface at ARRIA 10 GX
I work with arria 10 GX FPGA . I have block that implement serial flash interface that can read, write and erase sectors. I want to use this interface to work with the configuration flash (used DCLK,...
SreekumarR_G_Intel
7 years agoHello Niv,
I am sorry it is not possible to use the dedicated pin as the dual purpose pin.I took time to give a try before saying "NO".
Can it possible to use the SFL IP ?
there is generic IP available in the quartus , Can you give a try and let me know ?
Thank you ,
Sree
