mjuneja2007
1 year agoCritical Warning while generating SOF file for CXLtype 3 example design
Hi, I am getting below Critical Warning while generating SOF file for the example design of CXL IP type 3 with DDR4 controller for Agilex-7 board (DK-DEV-AGI027-RA). "Message ID :- 24567 The desi...
- 1 year ago
sounds like wrong design setup. Development board is using 125 MHz external oscillator as configuration clock, apparently you have selected internal oscillator as configuration clock in device options.
paveetirrasrie_Altera
1 year agoHello Madhur Juneja,
Good day to you.
Does clarification provided by our contributor helps?
Pavee
