AlfonsoSeletech
5 years agoCRC injection failure from Jtag Max10
Hi all, I'm testing the error detection and recovery functionality of a Max10 board. I injected it with the Jtag cable, by run a .jam file as shown in the AN-539 procedure related to the CRC code t...
YuanLi_S_Intel
5 years agoHi Alfonso,
Sorry for being late as i was checking with expert about this. By right it should be unless there is a real CRC error occur.
Probably you can try to disconnect the JTAG and see if it is really causing the problem.
Thank You.
