AlfonsoSeletech
5 years agoCRC injection failure from Jtag Max10
Hi all, I'm testing the error detection and recovery functionality of a Max10 board. I injected it with the Jtag cable, by run a .jam file as shown in the AN-539 procedure related to the CRC code t...
YuanLi_S_Intel
5 years agoHi Alfonso,
Just would like to understand further, so the JAM file you are programming is intended to cause CRC error?
Then at first, with the CRC error injection, the CRC error pin goes HIGH. Then after reconfiguration, with the CRC error injection, the CRC error pin does not go HIGH?
Also, is the image the same between both initial bootup image and reconfiguration image?
Please clarify.
Thank You.
- AlfonsoSeletech5 years ago
hi YuanLi_S_Intel,
with the CRC error injection, the CRC error pin goes HIGH correctly, but when I pull the nConfig pin LOW and then HIGH to reset the fpga I expect that the CRC err goes LOW but it remains HIGH instead.
the image after reconfiguration is the same.
Alfonso
