11 years agoControlling the Cyclone V clock
Hi, I have a Cyclone V demo board. There is a programmable clock on the board. The manual claims it "can be programmed through the clock control application in the examples/board_test_system ...
11 years agoOne thing to take note is that the frequency changed will reset to default after the board power cycle. You might need to set the frequency again after power cycle. You can use the clock control application to check the current frequency.
