12 years agoControl panel 2.1 cannot see DE1
I am using a DE1 with Quartus 13.1 and the Control Panel 2.0.1 on Windows 7 64 bit. When I first received the DE1 the control panel connected and barring a minor issue where I had to reboot the PC t...
10 years ago --- Quote Start --- using control panel 2.0.1, I get the following message: " Failed to find the FPGA board. Please make sure: 1. The FPGA Board and PC are connected by an USB cable. 2. The FPGA Board is power on. " I checked that the FPGA is connected to the computer and that it is on. The USB blaster driver is installed and I'm able to program the board through Quartus 13.0sp1. Please help --- Quote End --- Hi there, Are you also running DE1 control panel 2.0.1 in Windows 7 64-bit ? Have you tried the latest version 2.1 from our website de1.terasic.com ? What's worth trying is you can program the FPGA manually and launch DE1 control panel to see if the connection is established successfully. David from Terasic
