12 years agoControl panel 2.1 cannot see DE1
I am using a DE1 with Quartus 13.1 and the Control Panel 2.0.1 on Windows 7 64 bit. When I first received the DE1 the control panel connected and barring a minor issue where I had to reboot the PC t...
10 years agousing control panel 2.0.1, I get the following message:
" Failed to find the FPGA board. Please make sure: 1. The FPGA Board and PC are connected by an USB cable. 2. The FPGA Board is power on. " I checked that the FPGA is connected to the computer and that it is on. The USB blaster driver is installed and I'm able to program the board through Quartus 13.0sp1. Please help --- Quote Start --- Hi Andy, Could you please provide the error message when the control panel (version 2.1 or 2.0.1 ?) is trying to establish connection to your DE1 board ? The VGA output displays the blended color bars image could be the result of 1. the control panel is not connected or 2. re-compilation under a different version of Quartus II without additional setting in .sdc file. David from Terasic --- Quote End ---
