COntrol FPGA component from Linux
I am searching for a example that show me how to control fpga compionent from linux. I use cyclone 5 soc.
is there any example available to show that?
You can refer to this sample code to control LED on FPGA,
#include <stdio.h>
#include <unistd.h>
#include <fcntl.h>
#include <sys/mman.h>
#include "hps.h"
#include "stdint.h"
#include <termios.h>
/* The base address byte offset for the start of the ALT_LWFPGASLVS component. */
#define ALT_LWFPGASLVS_OFST 0xff200000
/* The base address byte offset for the start of the ALT_STM component. */
#define ALT_STM_OFST 0xfc000000
#define ALT_AXI_FPGASLVS_OFST (0xC0000000) // axi_master
#define HW_REGS_BASE ( ALT_STM_OFST )
#define HW_REGS_SPAN ( 0x40000000 )
#define HW_REGS_MASK ( HW_REGS_SPAN - 1 )
#define LED_PIO_BASE 0x10040
int main() {
void *virtual_base;
int fd, i;
int loop_count;
int led_direction;
int led_mask;
void *h2p_lw_led_addr;
int *ocram_src, *ocram_dest;
int *dma_base;
// map the address space for the LED registers into user space so we can interact with them.
// we'll actually map in the entire CSR span of the HPS since we want to access various registers within that span
if( ( fd = open( "/dev/mem", ( O_RDWR | O_SYNC ) ) ) == -1 ) {
printf( "ERROR: could not open \"/dev/mem\"...\n" );
return( 1 );
virtual_base = mmap( NULL, HW_REGS_SPAN, ( PROT_READ | PROT_WRITE ), MAP_SHARED, fd, ALT_AXI_FPGASLVS_OFST );
if( virtual_base == MAP_FAILED ) {
printf( "ERROR: mmap() failed...\n" );
close( fd );
return( 1 );
h2p_lw_led_addr=virtual_base + ( ( unsigned long )( ALT_LWFPGASLVS_OFST + LED_PIO_BASE ) & ( unsigned long)( HW_REGS_MASK ) );
// toggle the LEDs a bit
loop_count = 0;
led_mask = 0x01;
led_direction = 0; // 0: left to right direction
while( loop_count < 60 ) {
// control led
*(uint32_t *)h2p_lw_led_addr = ~led_mask;
// wait 100ms
usleep( 100*1000 );
// update led mask
if (led_direction == 0){
led_mask <<= 1;
if (led_mask == (0x01 << (LED_PIO_DATA_WIDTH-1)))
led_direction = 1;
}else{
led_mask >>= 1;
if (led_mask == 0x01){
led_direction = 0;
loop_count++;
} // while
// clean up our memory mapping and exit
if( munmap( virtual_base, HW_REGS_SPAN ) != 0 ) {
printf( "ERROR: munmap() failed...\n" );
close( fd );
return( 1 );
close( fd );
return( 0 );
- FawazJ_Altera
#include <stdio.h>
#include <unistd.h>
#include <fcntl.h>
#include "hps.h"
#include "stdint.h"
int main() {
void *virtual_base;
int fd, i;
int loop_count;
int led_direction;
int led_mask;
int *dma_base;
return( 1 );
close( fd );
return( 1 );
loop_count = 0;
led_mask = 0x01;
// control led
// wait 100ms
usleep( 100*1000 );
// update led mask
led_mask <<= 1;
led_direction = 1;
}else{
led_mask >>= 1;
led_direction = 0;
loop_count++;
} // while
close( fd );
return( 1 );
close( fd );
return( 0 );
- User1571932698773355
wow, thats beyond my expectations. thank you Fjumaah
