ocan
8 years agoConf done pin failed to go high in device1
Hi, I have a problem when my card is programming with JTAG. I opened with Quartus Prime 15.1 . I want to program with JTAG interface. But, Sometimes I click start button so I looked program fail...
ocan
8 years agoI sent my usb blaster fıigure, ı use USB Blaster RCN I. I can use MAX 10 FPGA. The confıgure pin that is config pin done. Do u know it that has a internal resistor.?
I read max10 datasheet, I just design 10K resistor pull up that connect to config pin done.
I think it is neccessary to configure .
After I did other suggestion , what do u think should I lower the resistor value ??
I measured config pin done's pull up resistor. It is apporixitemely 7K ohm . ı am sure the resistor value 10K ohm during multimeter.
I dont understand detaily :( What did it happen later which program failed :( ?
