KSmil
7 years ago"CONF_DONE pin failed to go high in device 1" - Arria 10 FPGA Dev Kit
I have been testing a design on an Arria 10 FPGA Dev Kit which uses the FMCA connection to send/receive signals between a couple of other designs on other development cards. The Arria 10 no longer l...
KSmil
7 years agoHi Nooraini,
I have tried it at both 16MHz and 6 MHz and the tests showed the same results. I can't see the top of the Arria 10 device, as it is under the heat sink. I am sure that the part number that is shown in the programmer matches the part number used in my design. I had been using this design for a couple of months before the issues started, so I know that the design functions correctly on the dev. board as well.
Karl
