KSmil
7 years ago"CONF_DONE pin failed to go high in device 1" - Arria 10 FPGA Dev Kit
I have been testing a design on an Arria 10 FPGA Dev Kit which uses the FMCA connection to send/receive signals between a couple of other designs on other development cards. The Arria 10 no longer l...
Nooraini_Y_Intel
7 years agoHi Karl,
Did you reduce the USB Blaster II cable TCK to either 16Mhz or 6Mhz before performing the tests that I requested? Can you check (to make sure) the part number (top marking of the Arria 10 device) matches to the part number that you set in your Quartus project design? If the actual Arria 10 part number is ES device, then Quartus your project design need to target the same ES part number.
Nooraini
