"CONF_DONE pin failed to go high in device 1" - Arria 10 FPGA Dev Kit
Hi Nooraini,
That test was carried out with a colleague, who is a JTAG expert. The test software was all on his laptop so unfortunately I don't have any screenshots.
I have attached a screenshot of Quartus programmer, when trying to program the A10 with a SOF file (jtag_fail).
I am able to program the flash separately (with a POF image, for example). The issue is that the Arria 10 does not configure after the flash has been programmed.
I have tried changing the JTAG frequence from 24MHz to 6MHz but the Arria 10 still did not configure.
I have also checked the status of the configuration pins,
MSEL = "001"
COND_DONE = '0'
nSTATUS = '1'
nCE = '0'
nCONFIG = '1'
dCLK = '0'
I have been using the Arria 10 Dev Kit for a few months now and it has all been fine. The design I am testing involves communicating with an existing design on another Dev Kit (Stratix III), vi the FMCA connection.
Karl
