KSmil
7 years ago"CONF_DONE pin failed to go high in device 1" - Arria 10 FPGA Dev Kit
I have been testing a design on an Arria 10 FPGA Dev Kit which uses the FMCA connection to send/receive signals between a couple of other designs on other development cards. The Arria 10 no longer l...
Nooraini_Y_Intel
7 years agoHi KSmil,
I'm not sure if I understand the second part of the test that you did. Perhaps you can provide some screen shots to show the test you did with the Arria 10 dev kit. Were you able to use the Arria 10 dev kit before the failure started to happen? You can try to reduce the USB Blaster II TCK to lower frequency such as 16Mhz or 6Mhz before trying to program the .sof file. Refer to the following KDB link on the steps to modify the USB Blaster II TCK value:
Nooraini
