KSmil
7 years ago"CONF_DONE pin failed to go high in device 1" - Arria 10 FPGA Dev Kit
I have been testing a design on an Arria 10 FPGA Dev Kit which uses the FMCA connection to send/receive signals between a couple of other designs on other development cards. The Arria 10 no longer l...
Nooraini_Y_Intel
7 years agoHi KSmil,
Are you referring the red LED to D16 LED? The D16 LED is just an indicator when the FPGA configuration from flash fails. Check all the jumper and switch setting on the board, make sure to set them back to the default factory setting. You can refer to the Arria 10 dev kit user guide for the default factory settings under chapter "Default Switch and Jumper Settings":
Then power up the board and monitor if the same D16 LED lights up or the D17 LED (Configuration done LED) lights up.
Nooraini
