14 years ago
CONF_DONE in failed to go high jtag
With the Cyclone III starter board my USB-JTAG pod fails to configure the board. The error in the Quartus message window is:
Error (209014): CONF_DONE pin failed to go high in device 1
The on board usb blaster works fine (just remove jumper JP8 to select the onboard mode).
The strange thing is it worked briefly (when I showed a colleague of course). While it worked I moved the pod around to see if the cable was the issue, but it kept working. Once I power cycled the board it stopped working in jtag mode (but the onboard circuit always works).
My brand new boards have the same problem - but only jtag mode, so I can not use any onboard blaster. With both boards the pod always detects the device ok, and gives reasonable sounding errors if I power off the board etc.
The debug Pod I have is a "USB blaster" rev B, with a ribbon cable that ends in a 10 pin header.
I am using JTAG mode so the MSEL pins are over-ridden, and I can not think of any other reasons why it should fail.
Thank you for your time and any advice you can give on this.
Steve
    The pod is surprisingly easy to open - has a little slot right on the lid. No warranty stickers.
    Its the cypress micro inside, cy7c68013a.
    After that there is a 74244, which is nice of them since it might keep the pod alive if I plug it in wrong. Or at least make it easier to fix :) (actually the 74244 is probably needed to set the the IO voltage levels)
    With the pcb out of the case it seems the micro is the one that warms up the entire pod.
    As soon as Chinese new year is over I am getting the Terasic pod. They are closed until the 30th.
    Thank you,
    Steve
    --- Quote Start ---
    --- Quote End ---
    Ok, this is a Cypress FX2. The USB-Blaster protocol was reverse engineered by Kolja Waschk and he wrote the original version of this code. Its subsequently been reused to implement these clones.
    --- Quote Start ---
    --- Quote End ---
    It shouldn't. The FX2 only draws a few milliamps. I wonder if they have an error in their firmware.
    --- Quote Start ---
    --- Quote End ---
    If you want to 're-task' your Cypress pod as a microcontroller development kit, let me know, and I'll post links to the Cypress FX2 download tool, and the open-source SDCC compiler.
    Cheers,
    Dave
    Good news -
    I took the ribon cable from the clone board and used it with the rev B usb blaster. Now everything works fine.
    It could be that I have a bad cable, but the posts at http://www.alteraforum.com/forum/showthread.php?t=21949 seemed like the cable is an issue.
    Could you provide the like to the cypress dev kit and compiler? I have a couple projects that could use something in this form factor (and price range)!
    Thank you,
    Steve
    --- Quote Start ---
    --- Quote End ---
    I installed EZ-USB_devtools_version_261700.zip which is available from here:
    http://www.cypress.com/?rid=14319
    It installs an old version of Keil uVision (version 2).
    The installation has example code.
    You can also use the open-source SDCC compiler to generate 8051 code. Send me an email and I'll send you a couple of blinky LED examples (I've only just started tinkering with an FX2 board).
    You'll need to know which pins/ports on the micro are connected to your USB-Blaster interface. Once you figure that out, you'll have yourself a GPIO board.
    Cheers,
    Dave
