14 years ago --- Quote Start --- The pod is surprisingly easy to open - has a little slot right on the lid. No warranty stickers. Its the cypress micro inside, cy7c68013a. After that there is a 74244, which is nice of them since it might keep the pod alive if I plug it in wrong. Or at least make it easier to fix :) (actually the 74244 is probably needed to set the the IO voltage levels) --- Quote End --- Ok, this is a Cypress FX2. The USB-Blaster protocol was reverse engineered by Kolja Waschk and he wrote the original version of this code. Its subsequently been reused to implement these clones. --- Quote Start --- With the pcb out of the case it seems the micro is the one that warms up the entire pod. --- Quote End --- It shouldn't. The FX2 only draws a few milliamps. I wonder if they have an error in their firmware. --- Quote Start --- As soon as Chinese new year is over I am getting the Terasic pod. They are closed until the 30th. --- Quote End --- If you want to 're-task' your Cypress pod as a microcontroller development kit, let me know, and I'll post links to the Cypress FX2 download tool, and the open-source SDCC compiler. Cheers, Dave
