14 years agoThe pod is surprisingly easy to open - has a little slot right on the lid. No warranty stickers.
Its the cypress micro inside, cy7c68013a. After that there is a 74244, which is nice of them since it might keep the pod alive if I plug it in wrong. Or at least make it easier to fix :) (actually the 74244 is probably needed to set the the IO voltage levels) With the pcb out of the case it seems the micro is the one that warms up the entire pod. As soon as Chinese new year is over I am getting the Terasic pod. They are closed until the 30th. Thank you, Steve
