14 years ago --- Quote Start --- Could you provide the like to the cypress dev kit and compiler? I have a couple projects that could use something in this form factor (and price range)! --- Quote End --- I installed EZ-USB_devtools_version_261700.zip which is available from here: http://www.cypress.com/?rid=14319 It installs an old version of Keil uVision (version 2). The installation has example code. You can also use the open-source SDCC compiler to generate 8051 code. Send me an email and I'll send you a couple of blinky LED examples (I've only just started tinkering with an FX2 board). You'll need to know which pins/ports on the micro are connected to your USB-Blaster interface. Once you figure that out, you'll have yourself a GPIO board. Cheers, Dave
