14 years agoCONF_DONE in failed to go high jtag
With the Cyclone III starter board my USB-JTAG pod fails to configure the board. The error in the Quartus message window is: Error (209014): CONF_DONE pin failed to go high in device 1 The...
14 years ago --- Quote Start --- The knock off pod works!! --- Quote End --- Great! Now pull the cover off, what is inside? :) --- Quote Start --- It is slower, a bit crashy, and feels warm. But that is so much better than the results I was getting from my other pod, which is apparently broken. --- Quote End --- Its $25 well spent now that you know where the problem is. --- Quote Start --- For the long term I think I will get a better pod. --- Quote End --- Go for the Terasic model. Cheers, Dave
