14 years agoCONF_DONE in failed to go high jtag
With the Cyclone III starter board my USB-JTAG pod fails to configure the board. The error in the Quartus message window is: Error (209014): CONF_DONE pin failed to go high in device 1 The...
14 years ago --- Quote Start --- Possibly its the pod? But it passed the jtag IDCODE tests... --- Quote End --- Depending on how they generate the IDCODE, you might have a problem with TMS or TDI. The IDCODE is loaded into the shift-DR register on TAP reset, i.e., TMS high and 6 TCK clocks. In that case, TMS does not get toggled. When the IDCODE is read out, TDI is a don't care, so that is also not tested. How about trying to read the USERCODE? Or put the device into BYPASS mode, and then just shift a bit pattern through the JTAG chain. Cheers, Dave
