14 years agoCONF_DONE in failed to go high jtag
With the Cyclone III starter board my USB-JTAG pod fails to configure the board. The error in the Quartus message window is: Error (209014): CONF_DONE pin failed to go high in device 1 The...
14 years ago --- Quote Start --- Thank you for your time and any advice you can give on this. --- Quote End --- Probe the JTAG pins with a scope. Make sure you use a short ground lead, eg., I'll often solder a loop of wire to a nearby capacitor ground and then loop that around the scope tip. Look at the signal integrity of the TCK pin first; look for ringing and a dip in its rising-edge (which can be caused by a transmission line reflection on that trace). Check the voltage high and low values of the signals. Compare those to the limits stated in the device handbook. Cheers, Dave
