RT0001's avatar
RT0001
7 years ago
Compilation error in assembler (generate programing file) part
Hi all,
i was compiling an AHDL code for flex 6000 (EPF6016ATC100-3) FPGA, and I got an error as " Configuration device EPC2 cannot configure device EPF6016AT00 ".
Please let me know why this error is coming and how to solve it (if i can use the same device, will be helpful )
    • RT0001's avatar
      RT0001
      Thank you Calvin Joazer for your response :) .
      By changing the Device and pin option in Assignments -> Device and changing the configuration to EPC1, which is available in Flex 6000, the same source file got compiled.
      the document you share was very much helpful.
      Have a good day.
