10 years agoCommunication between a PC and a Altera DE3 Board
Hello everyone, i would like to build up a communication between my DE3 Board and a PC. The DE3 Board only supplies ÙSB Communication can someone tell me the best way to do it?
10 years agoSetting up an Ethernet connection requires you to supply all the mentioned ports and your controllers should be compatible with it.
The mentioned board has a reference design which already has done all that. You'd better start with that reference design and then modify it to fit your needs and your FPGA part number.
