LRong3
7 years agoCode for HC-06 works on ModelSim but not on DE2-115 Board
Hi, I'm a student working on my project. I managed to write up a simple code for the HC-06 bluetooth module and it works fine. The code is shown below. The input by the bluetooth module is sent to th...
Abe
7 years agoI manged to modify your code and eliminate some of the latch inferences as well as other issues. But I'm not sure if it would work, ie, functionally correct. The rest is upto you.. correct the functionality while sticking to the same coding guide.. for FSMs etc. Check with the simulation and see if it works.. As stated earlier, the HC-06 has a UART interface it would be easier to implement a UART and communicate with it.
module FYP (
input wire clk,
input wire rst,
input wire Rx,
output reg [7:0] RxData
reg Tick;
reg [11:0] Baud_counter;
reg RxDone;
reg RxEn;
reg [4:0] start_counter;
reg ReadEn;
reg [4:0] counter;
reg [4:0] Bit;
reg [7:0] Rx_Data;
reg Rx_Done;
reg [4:0] holdCounter;
reg holdDone;
reg holdEn;
//State variables for FSM
reg [1:0] State;
parameter IDLE = 0, READ = 1;
reg [1:0] holdSTATE;
parameter HOLD = 0, RELEASE = 1;
always @(posedge clk or negedge rst) begin //setting tick at 16 times of Baud Rate 9600
if (!rst) begin
Baud_counter <= 11'b0;
Tick <= 1'b0;
end
else begin
if (Baud_counter < 325) begin
Baud_counter <= Baud_counter + 1'b1;
Tick <= 1'b0;
end
else begin
Tick <= 1'b1;
end
end // else
end//always
if (!rst) begin
start_counter <= 5'b0;
ReadEn <= 1'b0;
end
else begin
if (RxEn == 1'b1 && start_counter < 8 ) begin
start_counter <= start_counter + 1'b1;
ReadEn <= 1'b0;
end
else begin
if (RxDone == 1'b1) begin
ReadEn <= 1'b0;
end
else begin
start_counter <= start_counter;
ReadEn <= 1'b1;
end
end
end
end//always
if (!rst) begin
State <= IDLE;
end
else begin
case (State)
IDLE: if (Rx==0) State <= READ;
else State <= IDLE;
READ: if (RxDone==1) State <= IDLE;
else State <= READ;
default: State <= IDLE;
endcase
end //else
end //always
always@(State) begin
case (State)
READ: RxEn <= 1'b1;
IDLE: RxEn <= 1'b0;
default: RxEn <= 1'b0;
endcase
end //always
always @(posedge Tick or negedge rst) begin
if (!rst) begin
counter <= 0;
Rx_Done <= 1'b0;
Bit <= 1'b0;
Rx_Data <= 8'b0;
end
else begin
if (ReadEn==1) begin
if (Bit<8) begin
if (counter<16) begin
counter <= counter + 1'b1;
Rx_Done <= 0;
Bit <= Bit;
end
else begin
counter <= 0;
Rx_Done <= 0;
Rx_Data <= {Rx,Rx_Data[7:1]};
Bit <= Bit + 1'b1;
end //(counter<16)
end //(Bit <8)
else begin
counter <= 0;
Bit <= 0;
Rx_Done <= 1;
end
end //(ReadEn)
end
end
always@(posedge clk or negedge rst) begin
if (!rst) holdSTATE <= RELEASE;
else begin
case (holdSTATE)
RELEASE: if(Rx_Done==1) holdSTATE <= HOLD;
else holdSTATE <= RELEASE;
HOLD : if(holdDone==1) holdSTATE <= RELEASE;
else holdSTATE <= HOLD;
default: holdSTATE <= RELEASE;
endcase
end
end //always
always @(holdSTATE) begin
case (holdSTATE)
RELEASE: holdEn <= 1'b0;
HOLD : holdEn <= 1'b1;
default : holdEn <= 1'b0;
endcase
end //always
if(!rst) begin
holdCounter <= 0;
holdDone <= 0;
RxDone <= 0;
end
else begin
if (holdEn==1 && holdCounter<10) begin
holdCounter <= holdCounter + 1'b1;
RxDone <= 1'b1;
holdDone <= 0;
end
else begin
holdCounter <= 0;
RxDone <= 0;
holdDone <= 1'b1;
end
end
end //always
always @(posedge Tick) begin
if(RxDone==1) RxData = Rx_Data;
else RxData = RxData;
end
endmoduleLRong3
7 years agoThanks for the help. I'll try out the code and work on improving the FSM.
