18 years agoCII DSP kit audio examples using DSP Builder
I made a sample driver for TLV320AIC23 Stereo Audio CODEC chip which is mounted on CII DSP kits in Verilog-HDL. I attach the files with two very simple DSP Builder projects. sound_basic_dspb\sound...
17 years agohello EOFZ,
thanks for your kind reply. I could not, however, agree with you about the pin configurations of 2C35 and 2C70 board. I've attached the pin configuration file with this mail, can you please compare it with 2C70's pin configuration file? (I could not get that file from anywhere :( ). Can you please tell me which pins i should connect, and where? thanks in advance.
