18 years agoCII DSP kit audio examples using DSP Builder
I made a sample driver for TLV320AIC23 Stereo Audio CODEC chip which is mounted on CII DSP kits in Verilog-HDL. I attach the files with two very simple DSP Builder projects. sound_basic_dspb\sound...
18 years agoHi EOFZ,
I have downloaded and use your excellent codec interface files. It works properly on EP2S60 DK and all I had to do was pins assignment. I analyzed your code and simulink model . I don't understand the logics of synchronizing clocks. BCLK = 40MHz /16 and SCLK 40MHz/32 . Following your registers mapping the interface works in USB clock mode i.e. 12MHz . After I changed Sample Rate Control Register to 8 Khz input and output the results I received were the cut off 6KHz which means 12Khz sample rate. I'll really appreciate your help. yan_w
